Results 1 to 3 of 3
Thread: Chasing coolant loses.
    Anderson Island, WA
    Default Chasing coolant loses.
    1992 e32 735i m30 160,000 miles
    I had an overheat issue; and now -- I think we've determined what is really going on.
    We now believe I'm loosing coolant while I drive, via a head gasket leak forcing fluid into the overflow & pressure pushing it out the drain hose.
    It's not too bad of a leak, as far as no water in the oil, no oil loss, no oil in the coolant, etc etc etc.
    We're pulling the head off -- anything I need or should do while we have the head off?
    I was thinking about a bit of porting/polishing work -- headers appear out of the question price wise. I was also thinking about replacing the timing chain tensioner - is the chain doable at the same time?
    Any pipes, hoses, etc that will probably go bad and are a pain to get at otherwise?
    I was going to use new headbolts. The cam looks good, so I dont' think I *need* a new cam.... Are there things to specifically look for? Would I need new rocker arms if I changed the cam?
    -josh
    Maybe you ask the guys on a special E32 board.
    http://www.bimmerboard.com/forums/e32/
    If I start now telling you what to change all now then you finally would end up with almost a new engine ;-)
    Anderson Island, WA
    Thanks -- yes; well; I'm not willing to do a radiator cap rebuild.... (rebuild everything under the cap -- aka a new car)
    The car runs fine; plenty of power, even compression; no oil consumption -- just this darn coolant loss...
    Thanks for the link.
    -josh
  1. Tired of chasing A/C leaks!
    By John B. in forum 5 Series BMW
    Last Post: 08-15-2009, 08:27 AM
  2. Chasing the brake shimmy
    By ILoveMPower in forum 5 Series BMW
    Last Post: 11-10-2008, 11:36 PM
  3. Tow Truck Chasing
    By Blitzkrieg Bob in forum 5 Series BMW
    Last Post: 05-22-2006, 08:22 PM
  4. 535i loses power
    By gushmagesh in forum 5 Series BMW
    Last Post: 10-08-2004, 11:13 PM
  5. e34 m5 chasing audi s4 video
    By misfortune in forum 5 Series BMW
    Last Post: 10-05-2004, 08:48 AM
