first time i've ever heard of the lines rusting
u parking in an ocean or something ?![]()
After replacing the fuel lines quite a few times on this e34, they are quite vulnerable under the car and here in uk they rust rather quickly.
I know on a citroen we have the fuel lines run inside the car, any thoughts on issues I may have if I run them through the conduit under the carpet on the E34 using high pressure hose
chris
Use the OEM part and seal them with an appropriate underbody coating/rust inhibitor (por 15?)
They should last at least 8 years in extreme conditions. How many times have you replaced the brake lines?
best, whit
Safety...that seems a bitto me.
id get a bender and make them up from something less reactive, or get some factory lines and encase them in heater hose or something
A 1994 518i that you've owned since 1989/15 years? What kind of car are we talking about here?!Originally Posted by cschollum
Silly putting all that salt on the road huh. Why not go for stainless steel? I know you can use braided hose (easy to run but less strong than a solid tube. It can't be that hard, it took me an hour to do a braided line on a turbo Mazda (the original line needed to be made larger)
. It may not be as safe (braided lines) as solid ones (but solid is PIA to put in) If it is beside the rails and well fastened, you shouldn't have a problem.
Don't some rally cars have internal fuel lines too?
Cheers,
Shaun
