Results 1 to 10 of 10
Thread: Can someone help with the main relay on M50?
    PA
    Default Can someone help with the main relay on M50?
    I am trying tap the switched +12v side of the main relay so that I can power my aftermarket ECU from it. I successfully pulled the relay and such and started probing but I ran out of time.
    so yeah, I am trying to tap the switched power from the main relay, but i don't have a diagram and i don't feel like probing it and shorting something that shouldn't be.
    anyone have a reference for main relay on M50 non vanos?
    #4 is the main relay.
    pin 87 is the switched power 30 is the supply 85/86 are the switching
    PA
    Thanks winfred, so hook up megasquirts 12VDC input to 87?
    Also, do you know if the injectors are fused?
    The MS diagram assumes the injectors will be getting 12VDC from the main relay also... is this true?
    yes to 87, no to fused and yes to 12v from main relay
    PA
    LOL I like your answer format.
    should I fuse those bad boys, as a 'just in case'?
    only if you think you are going to build a crappy short prone harness seriously i wouldn't, one more place for corosion and bad connections
    PA
    The MS ecu is fused 2A, so I assume if something is wrong that'll blow before the injectors catch fire
    Jul 2005
    New York
    ho-lee-****. am i just thick or is that confusing as hell
    You're my hero.
    PA
    its not that bad actually
    if i had to i could draw that from memory it's just a simplified wiring diagram, you want confusing look at a old volvo schmatic
    Quote Originally Posted by angrypancake
  1. main/dme relay?
    Last Post: 12-12-2009, 01:27 PM
  2. '92 525 - main relay triggered by ground or 12v?
    Last Post: 12-16-2008, 05:26 PM
  3. Serious main relay issues
    By ichbinsobose in forum 5 Series BMW
    Last Post: 04-06-2008, 05:17 PM
  4. Main relay - 1992 525
    Last Post: 04-11-2007, 08:39 AM
  5. M50 coils, main relay or fuel pump relay?
    Last Post: 05-31-2006, 07:48 PM
