At around 210,000 miles, I had my auto transmission replaced with one I got at a junk yard.
It worked fine for a bout 1.5 years. Now it is hesitating going from 1st to second - like it was a manual transmission and you're releasing the clutch very slowly.
I have read it might need more fluid.
I have the Bentley manual and read there are two types of trannys for that car. One where you can add oil and one that never needs oil replaced.
I see what looks like a dipstuick tube in the engine compartment going toward the tranny but I can't get the top off of it.
I don't know if I had a permanent fluid tranny and the tranny was replaced with one that where you can add fluid or vice cersa.
Either way, I need to find out if the fluid is low so I can try this tactic first before I take it to a shop.
Does anyone know how to find out if the fluid is low?
