This fix works on my wife's Volvo, maybe it will work here.
Originally Posted by Jon K
I don't know whats goin on here. I have yet to inspect bulbs, but sometimes when i move my indicator stalk to the left side it blinks fast like there is a bulb out... but i can see my bulbs in reflection of other cars... theyre just blinking fast.. right side is fine. What gives? Any idea guys? Could it be the cold? Its like 25 here.
My 86 325E did that when my sidemarker light burned out. I put in a new bulb and it stopped but it started again after a few days because water was leaking in.
It's not the sidemarker bulb. Those of us running European trim delete the sidemarker bulbs and it makes no difference.
The rear bulb is the usual suspect in this case and just needs the silver contacts shined up a bit.
Jr
low blinker fluid?
sounds like one of the bulbs is intermittent somewhere, ie, front shows but back is flacking out occasionally.
Isn't that what the Warthog needs in Halo???Originally Posted by ryan roopnarine
I miss my e34
same thing as a brillo pad and stabilant 22, that stuff is like magic.
Agreed Jon.........those of us in high humidity climates that can drop up to 50 degrees overnite can easily be the victims of light corrosion and moisture.
I've also found that the bulb quality of today can be BAD right off the shelf too !
Many times I've run the problems down to loose steel bulb housings from the glass etc.Junk.
Shooting some light WD40 or better when installing new bulbs can conquer the two issues of condensation gathering around contacts and ALSO reducing the stress on the cheaply made bulb construction.![]()
...............Damn its getting COLD !!lol
...............Vinny
AC Schnitzer | S-5 | Stainless exhaust | Bodykit | wing| 3pc. wheels | badges | springs | mirrors | steerwheel |
Schwarz on Blk
Isn't that the side your supercharger is on? You might have to get another supercharger for the other side...![]()
Originally Posted by Jr ///M5
crap its the electro magnetic field emitter hooked to the supercharger!!!!
Thanks JR!!!
