sand blasting material is silica particles with sharp edges and it is used for harder metals. it can actually remove material, especially on softer metals
glass beads in bead blasting are round pieces of glass that hit the material and shatter. This destroys less of the material and helps clean the surface.
Yes...I used forced air for a long time on the intake manifold, valve cover (with plate on the inside removed), and oil pan for a long time to make sure no blasting material was leftover
I will weigh the block when I get it back
Originally Posted by kyleN20
