Ok folks, what is the best way to remove rear speakers on a 95/525i? My right rear I think is cracked. I've read the threads but nothing says how to remove. I don't to tair up my rear deck.
tunes mobile
This reply is kinda late, but....Originally Posted by Larry Looney
I have the Bentley manual and it shows a think screw driver prying (gently) the grille up from the middle of the inside of the cover. However, the trick is getting all of the screws out of the actual speaker itself. You'll need bright light and a lot of patience. Careful in replacing it with something other than the same spec speaker. I read it may cause problems with the system.
i have my original rears if u want em *edit i have the subwoofer but the tweets are toast
to get at the speaker is easy.. flat head screwdriver.. pry off the top cover and you should easily be able to get at the speakers with a short phillips screwdriver
-inc
'91 e31 850
'90 e34 535
'02 CBR F4i stunt/track bike
'07 gsxr 750 stunt bike
Thanks guys, I'll try it as soon as I get over the crud. yukyuk & yuk
tunes mobile
