I had the same question. I thought a bulb was burnt, but one night while I was tapping on the dash to get the gear selector lever backlit poof - they came on! Must be a loose connection because they're intermittent. Good luck with yours.
Hi guys, as some of you know I got my e34 last week so I'm still figuring out how everything works. I'd like to know if the climate control dials (the 3 dials) are supposed to be backlit? I can't make out the temperature readings at night, I was thinking maybe the bulb was burnt as it would seem a bit silly to leave this area of the dash unlit. Is it lit at all?
1995 525iM - 131k - Alternator play, broken s-belt
1995 525iA - 147k - Tensioner weirdness, broken s-belt
2001 Intgra GS-R - 130k - spun bearing
2002 Honda Odyssey - 80k - fragged transmission
Must be a common problem, mine is the same way. I assumed it to be a goofy design.
Resolder everything inside. Here some pics of my open units:
http://www.emip.de/up/Klima-LED-Wechsel-02.jpg
http://www.emip.de/up/Klima-LED-Wechsel-03.jpg
http://www.emip.de/up/Klima-LED-Wechsel-04.jpg
http://www.emip.de/up/Klima-LED-Wechsel-05.jpg
http://www.emip.de/up/Klima-LED-Wechsel-06.jpg
http://www.emip.de/up/Klima-LED-Wechsel-07.jpg
http://www.emip.de/up/Klima-LED-Wechsel-08.jpg
