Results 1 to 7 of 7
Thread: A few Fuel Line Replacement Questions
    Default A few Fuel Line Replacement Questions
    I'm getting ready to replace the fuel line on my 93 525iT. I have a couple of questions for those who've done this before.
    1) What is the size of the line...10mm?
    2) To do the whole engine bay I'm estimating 2 meters of line. Is that a good guess.
    3) As the fuel line goes into the rail, there is some type of fitting that is circular and has a band/strap type clamp. The area seems just a little wet occasionally. I've tried to tigthen the strap (philips screw adjuster) but I think something else in that fitting miht be failing. What does this part do, and does anyone know that part numbers I need to replace/fix this?
    4) The vent line coming out of the front of the valve cover really needs replacement...it is very brittle. Is there a specification/diameter on this line? It certainly does not need to be FI line, just some type of fuel/vent line.
    Thanks for any advice.
    -Phil
    I ordered 2.5 Meter for my V12 engine room, and that was enough. So I assume with 2 Meters you are fine.
    Buy enough clamps.
    Use the real OEM catalog to find the right sizes
    http://www.realoem.com/bmw/select.do...938848d4d39ea1
    and also www.autohausaz.com is a good help. Type in your car and year spec and that will guide you.
    I ordered everything from Autohaus Arizona.
    Buy more than two meters, because you'll invariably want to use pieces here and there (around the fuel filter, for instance), and it's handy to have some extra around.
    I think you're talking about the fuel pressure regulator. Does the wetness smell like gas? It should. Don't worry about replacing it unless the car has a rough idle/other weird operating characteristics that indicate it needs to be fixed. More than likely, the hose clamp is bad, causing fuel pressure to bleed off and <temporary> wetness.
    Those vent lines should be part numbered, fitted lines -- ie, the parts themselves should be purchased for their replacement, versus a length of generic hose. If oil is leaking past the fitting in the valve cover, or the fitting feels loose in the cover, replace it as well.
    best, whit
    Apr 2005
    IL
    Why does one line corrode more than the other? ... return vs. supply ... I've noticed this on a number of different types of cars.
    Ken
    So which ones were more corroded?
    I can imagine one thing: temperature of the fuel.
    In the return line it is warmer than in the feed line, because it went trhough the complete hot engine room.
    My car has even a return line which first goes thru the aircon line !! to cool the fuel down before it returns to the fuel tank.
    Here a pic (that was before cleaning the engine room and replacing all hoses)
    http://www.bimmerboard.com/forums/posts/119761/
    Default Thanks
    I'll get a few meters+clamps and give it a whirl. Thanks for the advice.
    -Phil
    PA
    Quote Originally Posted by pwalk100
    -Phil
    Whatever you do - MAKE SURE that if you're replacing an injection line that it is rated for fuel injection. The idiot at pepboys cut me a length of fuel line rated for carb'd cars (15 psi) or fuel return, and told me it was rated for injection. 70psi TORE through that bitch, I lost a bunch of fuel on the Newtown Bypass.
  1. fuel line
    By ski.doggy in forum 5 Series BMW
    Last Post: 10-08-2006, 09:49 PM
  2. BMW fuel line cooler...
    By genphreak in forum 5 Series BMW
    Last Post: 10-08-2006, 08:44 AM
  3. Rigid fuel line replacement
    By pfmc24 in forum 5 Series BMW
    Last Post: 08-29-2006, 12:00 PM
  4. Fuel line to fuel rail, pipe bursts
    By Mozarts_Ghost in forum 5 Series BMW
    Last Post: 04-14-2006, 12:52 AM
  5. fuel line replacment fix
    Last Post: 10-21-2005, 08:28 AM
