Do you guys have any tips on replacing all six of them? I understand I don't have to remove the intake manifold and they should come out with the fuel rail in one piece.
the rail comes off the top of the injectors, theres some cheesy plastic clips that hold them to the rail...I broke all mine. The injectors pull out of the intake and have rubber O rings, you need to lube the new ones with gear lube or equivilent and push them down until seated. Make sure you get all the dirt and stuff out of that area before you do this project.
Good price on injectors here.
http://www.fiveomotorsport.com/Injector_SetsBMW.asp
