Thread: oil leak...92 525iTa...left side near the...
    Pembroke Pines, FL
    Default oil leak...92 525iTa...left side near the...
    front of engine by oil pan. I think I read something about the crank position switch area (which I do not know where that is) about second cylider back on engine from front. Hard to see down there around suspension & oil pan. I replace the sending unit on bottom of pan because from driveway that's where I thought it was dripping. N-o-o-o, too easy. Anybody recall that crank sensor oil leak related post?
    Pembroke Pines, FL
    Default Anybody?
    The post wasn't that long ago.
    Pembroke Pines, FL
    Default Can you hear me now?
    (no pun intended)
    Coastal North Carolina
    Perhaps your valve cover gasket is leaking and the oil is running down the side of the block, past the exhaust manifold and to the pan?
    There is also a gasket between the timing case and the block. That gasket may be leaking. It is a two piece gasket.
    I would clean the engine well and then look closely for the leaking oil.
    Scott
    Wilmington, NC
    01 525iA For Sale
    Coming Soon: 2005 X3 3.0i
    05 Jeep GCL HEMI
    85 318iA SOLD
    96 Jeep GCL SOLD
    Pembroke Pines, FL
    Default Thanks, Scott...I cleaned it pretty good but still hard to
    see up in there from laying on my back in the driveway. Could be that timing gasket but I'll also check the valve cover. I hope that is the one!
    Unregistered Guest
    Mine has a leak, but it is the crank seal (M50 engine) I have replaced the oil pan & valve cover gaskets, but still have the leak. It is not worth the time or money in my case to fix it.
    Jim
  1. Replies: 6
    Last Post: 03-13-2009, 02:25 AM
  2. Hot Air blowing from the left side with the AC on
    By grave77 in forum 5 Series BMW
    Last Post: 10-10-2004, 07:20 PM
  3. Are the lock motors the same on the left and right side?
    By NielsGalan in forum 5 Series BMW
    Last Post: 09-23-2004, 05:39 AM
  4. Is there left and right side for cross drilled rotors?
    Last Post: 06-06-2004, 05:27 PM
