Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Where do engine codes show up?
    Dec 2005
    Brisbane Australia
    http://www.bmwe34.net/E34main/Trouble/Engine_codes.htm
    If you look down in the lower part of the page under the heading "Older E34 bulb wiring"
    It says the the 88 and 89 e34s had the stomp test but no bulb in the socket, as it would flash constantly, however if you did put a bulb in, the stomp test will still display codes. This maybe the source of zee problem ja.
    TO, CA, NA, EA
    My car shows no codes either. First I thought it was maybe OBDII since it's a 95, but reading this makes me think it is because it's Canadian spec. Will a Peake tool still work?
    Nov 2005
    OK, so if the check engine light is not on I'll not get any codes at all? I only see the check engine light when I turn the key on and not after, so I shouldn't see any codes if the light is not on, right?
    Nov 2005
    La Jolla, CA/ASU
    Quote Originally Posted by laguner
    You will only get codes if the check engine light is on while the car is actually running. Its supposed to be on when you turn the key.
    Jeremy Bull
  1. Check Engine codes?
    By elbasha in forum 5 Series BMW
    Last Post: 07-07-2008, 07:24 PM
  2. Reading Engine Codes?
    Last Post: 07-04-2007, 11:54 PM
  3. engine codes
    By darron525 in forum 5 Series BMW
    Last Post: 01-27-2005, 01:21 PM
  4. Check engine codes
    By karl1171 in forum 5 Series BMW
    Last Post: 08-19-2004, 05:43 PM
  5. Trying to get engine codes
    By phildg2000 in forum 5 Series BMW
    Last Post: 07-14-2004, 08:46 AM
