Results 1 to 8 of 8
Thread: Help in identifying these parts
    Aug 2005
    Default Help in identifying these parts
    I had a crash, car is nearly repaired. But there are some parts guys repairing the car do not know.
    Anybody can tell me what these things are and where they are supposed to be?
    The small one with a wire attached is located on the front right side of the car. I thought it might be related with the car alarm system. Car alarm system used to blip when somebody approaches or passes by close to the car.
    Second one is something plastic, definitely from the engine bay.
    After the crash car was in a bad condition. Those parts simply lay inside the engine campartment. Guys doing the bodywork did not unscrew them so they have no idea what these things are.
    1994 520i with M50 engine, manual transmission and air conditioner.
    VIN: GG45422
    Kentucky
    The thing in pictures 3 and 4 looks like the plastic covers that goes behind the lights and in front of the airbox.
    As for the first thing ... Did you check where the wires are going? That might help us figure it out.
    Aug 2005
    I will check the wires tomorrow. There is a lot of things in there.
    VIN: GG45422
    the first 2 look like some sort of sensor, probably for the alarm like your guessing. The 2nd set is the cover for the air intake like Tiger says but it looks like its busted up pretty good, need a new one for sure.
    Aug 2004
    detroit
    first one almost looks like a horn, but if you said it bliped when people walked by, it could be some sort of moation sensor, and the second dose look like behind headlight covers, with air ducting and such.
    Aug 2005
    OK, thanks everybody.
    VIN: GG45422
    Jun 2005
    Cheshire, UK
    Default Just my $0.02 worth:
    Does your car have heated washer nozzles? The thing in pics 1&2 look like the thermister (temperature dependent resistor) that controls the heating circuit for the nozzles. It fits near the air box.
    Aug 2005
    I don't know. Will need to look into that.
    That thing (1&2) is located somehwere under/near the washer tank. And there is one connector that guys at service have no idea about. Everything seems to be connected but one connector is staying alone. In this thread people seem to have the same issue:
    http://www.bimmer.info/forum/showthr...t=16692&page=2
    VIN: GG45422
  1. Help Identifying a Whine?
    By Jehu in forum 5 Series BMW
    Last Post: 02-16-2010, 10:13 PM
  2. Help Identifying 18 inch Rim
    By Rodericb in forum 5 Series BMW
    Last Post: 10-26-2007, 12:17 AM
  3. need help identifying something
    By panzershreck in forum 5 Series BMW
    Last Post: 06-01-2007, 12:29 AM
  4. Identifying tranmission ZF vs GM
    By JMI in forum 5 Series BMW
    Last Post: 10-23-2006, 02:19 AM
  5. Identifying an imported e34
    By IN10CT in forum 5 Series BMW
    Last Post: 07-07-2005, 11:23 PM
