Originally Posted by
AZ_Jason_S
I would suggest getting one of the clips that hold the radiator to the core support. I broke mine removing it. Possibly also 1 or 2 of the expansion nut that hold the shroud to the radiator. You have to remove the black plastic cap on top of the tank. The clip for the radiator/support inserts into that. I think the shroud also inserts into that piece. After you get the 3 allen heads off, pop the black cap piece. Then the tank just lifts out. It may not want to at first but just keep working on it. There is one O ring around the bottom, another small one on the top. I only really needed the bottom one, but I did the other one anyway. Took me about 20 minutes. Also, I tried to clean the mating surface down in the rad. where the tank inserts. I also put a real light touch of grease on the big O ring. I didn't want it to tear when I pushed the tank back in. Lastly, I didn't do anything with the sending unit.
