Results 1 to 10 of 20
Thread: Engine warmer option
    Calgary AB Canada
    Default Engine warmer option
    My car never had a block heater from new and my stealer told me you can't put one in an M5 due to the high performance cooling system. Anybody ever try one of these?
    http://www.dieselproducts.com/proheat/proheat.html
    The model 512 is under $100CDN and installs in minutes. An attractive option since it's -25C this morning.
    Baby Polar bear: Mommy, what kind of bear am I?
    Mama Polar bear: Why a Polar bear of course.
    Baby Polar bear: Are you sure I'm a Polar bear?
    Mama Polar bear: Of course I'm sure, your fur is white, isn't it?
    Baby Polar bear: Well, yes it is but are you really sure I'm a Polar bear?
    Mama Polar bear: For the last time, I'm sure you're a Polar bear. Why do you ask?
    Baby Polar bear: Because I'm f-ing freezing!
    Anthony
    03/64 production
    Hockinson, Washington
    If you look closely at the picture and read the other pages, it plugs in. It looks like its basically an electric blanket for your oil pan. Not that i would know, but it doesnt seem like that could interfere with the cooling system...
    Calgary AB Canada
    It's a 250W electric heating pad that sticks to the oil pan and warms the oil. Uses half the power of a typical block heater and puts the heat where it's needed so the oil flows quickly on frigid mornings.
    The usual immersion (think electric kettle) type heater fits through one of the (mis-named) freeze plugs to boil the coolant. I had one of these blow out on my 325 so am inclined to be leery of them on a car that sees 7000+ on a regular basis.
    $100C is much cheaper than the labour to install a $20 immersion heater.
    Anthony
    03/64 production
    PA
    Quote Originally Posted by Anthony (M5 in Calgary)
    Truth is...
    You're going to have a HELL of a time getting that to stick to the bottom of the oil pan. If the oil/dirt isn't enough to defeat adhesion, the contour of the pan is. If you did manage to scrub the pan clean/sandblast (dropping a pan is a lot more than $100) you'd still need to make it fit to the ribbed pan. And even still... Our pans are thicker than the domestic 16 gauge aluminumized steel pans. I find it hard to believe that would heat oil up to an operable temperature range. A block heater is much preferred.
    Calgary AB Canada
    Truth is...
    The bottom of the sump is flat and smooth with no ribs 'cuz the M5 uses an aux oil cooler. The heater (3.5" x 4.5") is far smaller than the flat area of the pan. De-greaser is used to make the surface ready for the adhesive and the silicone is to weatherproof the edge seal. Besides, the pan is already clean and oil free. Heating through the thicker aluminum should make no difference since aluminum is an excellent thermal conductor.
    All that said, I found nothing about CSA/UL approval for the heater and I've asked the supplier for this info. That may be the deal breaker. All testimonials aside, electrical safety is more important than installed cost.
    Anthony
    03/64 production
    if you can get it to stick up there I think it might be a good idea to have the oil warmer than ambient temperatures. This will not hurt the cooling system like conventional antifreeze block heaters.
    May 2005
    central coast nsw au
    i've never heard of this before. is this for real? **** I remeber my mother once many years ago using a hair dryer much to the amusement of my father and neighbors to heat an old morris minor to no avail of course. I think even at 6 years old I understood that it was a non event. But is it a reality that u guys have such technoligy available and do people use it? BTW it was so ****n hot here today my 2 computers shut down for 4 hours. maybe 48+ c all friggin day and now at 2.35 am its still 20 something. good beer weather jeff!
    PA
    All the degreaser in the world can be used, the only way to get an adhesive to stick to an aluminum surface reliably would be with an etcher.
    Ohhh I dont doubt it will be a challange, I just said "if" he can get it to stick it sounds like a good idea.
    Default I think that would be no problem at all, even if he couldn't get it to
    bond 100% its easy enough to run straps from the pan bolts across the bottom of the pan over the heater and to the opposite side pan bolt. He can even sandwich a aluminum plate to squeeze it tightly against the bottom of the pan.
  1. DTC option
    By Claude in forum 5 Series BMW
    Last Post: 02-04-2009, 07:39 PM
  2. Seat warmer bulbs - fix
    By scott 4991 in forum 5 Series BMW
    Last Post: 01-02-2007, 08:41 AM
  3. Battery Warmer Blanket-type
    Last Post: 11-30-2006, 08:05 PM
  4. I need e34 v8 owner's option!!!!
    By chefdanny121 in forum 5 Series BMW
    Last Post: 11-24-2005, 11:29 PM
  5. Finally a bit warmer...first clean.
    By gordon in forum 5 Series BMW
    Last Post: 04-09-2004, 02:58 PM
