Results 1 to 10 of 14
Thread: wheel bearing hubs and brake rotors front
    Sep 2005
    New Mexico
    Default wheel bearing hubs and brake rotors front
    Who can tell me how to change the bearing hubs and front rotors on a 1995 525i? I have vibration/shimmy and have change tierods, thrust arms, tires, wheels. What's next?
    tunes mobile
    Pleasanton, California
    Do you have a shimmy during normal driving or only during braking? If it's normal driving the rotors shouldn't be a problem.
    Curt.
    Curt.
    1994 530iT (gone but not forgotten since I see it every day!)
    1991 M5
    Quote Originally Posted by Larry Looney
    www.bmwe34.net
    also, search "Johan & Sean's E32 page" -- on the forum or google -- they've got a decent writeup.
    Do a search for how to check the bearings themselves -- I've posted that info a number of times in the past, as have others. Warped rotors usually only cause a shimmy on braking. Check your shocks/strut inserts. Be certain the wheels are hubcentric and the correct (on the lower side of medium) offset.
    best, whit
    Sep 2005
    New Mexico
    The car has vib/shim at 40 to 60-70 mph. At 60-70 I feel it in my butt and a little in the steering wheel. I have hubcentric rings on all 4 wheels. The wheel hub is cut to 74.1mm. I think my hub is 72.5mm. Wheels are 17"X7.5". I don't under stand the lower side of medium off set? I don't understand the off set stuff. Could wheel bearings do this? Had front align 3 times. Every time I replace a part. Car has 82,321 miles and in Great shape, just the darn thing shakes. Could it be in the rear some where?
    tunes mobile
    probably the hubcentric rings or an out of round tire.
    Jan 2005
    Ashland, Oregon
    If you had your stock wheels on before and no vibration, it's gotta be wheel/tire related. Make sure you have good hubcentric rings, I got a set off ebay that were supposedly 72.5mm - 74.1mm, but they weren't doin ****. Found a local place that had some in stock and they were visibly thicker. That's more than likely your problem.
    As far as wheel offset... you should be right around ET 20. Should say inside the wheel.
    If your bearings are shot, you'd probably hear a scraping or grinding.
    94 540i / 255k / 165k on the alusil / E.A.T. chip / Power Discs w/Akebono Pro Ceramic / E39 type 33's
    -Brandon G
    Sep 2005
    New Mexico
    Where do I find the thicker ones? I bought the hub rings off ebay also. They were Alum. I bought some plastic rings from a tire store.N good, put the alum over tthe plastic and put the wheel on and vib went away. So, where do I get thick ones?
    tunes mobile
    Tirerack. Do a search for the part number, it's also available on Bruno's site. ~ $24 shipped in the US for aluminum ones. Call them -- they'll know what you're talking about.
    Sep 2005
    New Mexico
    Thanks for the information. I'll try them.
    tunes mobile
    where do we get the plastic ones?
    (im so damn lazy, i'll look this up later and post the info)
  1. Replacing Front Wheel Hub/Bearing
    By Mitch90535im in forum 5 Series BMW
    Last Post: 08-21-2011, 04:15 PM
  2. Front wheel bearing questions
    By atomicDog in forum 5 Series BMW
    Last Post: 11-13-2005, 08:34 AM
  3. Replies: 1
    Last Post: 03-12-2005, 06:40 PM
  4. front wheel bearing replacement
    By bpattan in forum 3 Series BMW
    Last Post: 08-23-2004, 02:21 PM
  5. Front wheel bearing
    By trevorg in forum 5 Series BMW
    Last Post: 07-31-2004, 10:27 PM
