I can't see the heater/ac fan knob at all at night, or the temperature knobs for that matter. I'm guessing there's a bulb behind the knob that's burned out. Is it hard to replace?
My bulb is being changed on Monday when it goes to the specialist Be emms in Sydney (quick plug!). Yes it will light up. Check the archive for a thread on how to change it yourself.
Cheers
Wingman
'89 525i/A Exec 193000kms
'94 Subaru Liberty AWD Wagon
Looking for Merc 300TE
NSW, Australia
Originally Posted by wingman
but i took it apart to relise its the dam little circut board not the bulb , so i am looking on ebay for the a/c control board , its easy to just change the bulb just becareful with the vent cables. original location color coded red , green , blue.
Strap
Mine were out when I got the car. There's 2 or 3 bulbs back there. I think Bruno covers the subject.Originally Posted by Picatavi
Yes there are bulbs back there. To access them you need to remove the radio and the fan cables and push the control module out. You will need to remove the plastic backing from the ac/heater controls to access the lights.
The lights use 12v 1.2watt bulbs I believe. The same bulbs that go in your dash cluster (the small ones, not the three big ones) will work although they might not look exactly the same.
It's an easy job, just takes a little bit of time to figure it out. There's not much you can screw up as long as you keep all of the screws you remove in a safe place and remember which order the fan cables go in.
I just had to replace my OBC lights and my fan control lights about two weeks ago, so the procedure is still pretty fresh in my mind. Bentley manual helps, but isn't necessary at all.
