Results 1 to 10 of 14
Thread: Coolant level warning displays only at start up?
    Apr 2004
    Default Coolant level warning displays only at start up?
    Coolant level warning displays only at start up? What's up with that? "89 525 180k mi.
    Apex, NC
    Mine will do that when it is right at the sensor level. When warm the coolant expands, so you don't get the warning. When cold... well you get the idea.
    Scott
    '11 TSX Sport Wagon
    '00 328i
    '78 MGB
    '08 Saab Aero
    Same here in my M60 530i.
    I've got a small leak somewhere in the heater core. $$ to repair, so I live with it, as it is minor. I typically get the message when cold, once started, gone within 30 sec. Testing after a hot-restart shows no message.
    uberhahn
    '94 530i 5-speed. The work begins...
    Houston, TX (USA)
    Take the coolant level sensor connector out and short 2 terminals with a jumper wire. Then start the engine. If you don't get that message now, means your sensor is bad. I replaced mine 2 weeks ago. I had the same problem as you have.
    Washington DC
    Quote Originally Posted by uberhahn
    uberhahn
    Heater core is a rather inexpensive repair if you do the work yourself. Cost for parts is under $150. It is a bit of a pain but Johntee540 and I can walk you through it after we learned the hard way.
    Apr 2005
    IL
    Also ... take a look in the expansion tank ... if you see something floating around the top and looks like a tube ... it's the float from the sensor. I had this happen.
    Ken
    Wellington,New Zealand
    dont you also get the warning when you switch of????(if you have had the warning at all)
    Gone but not forgotten
    Durban, South Africa
    Yeah I think you do. I get Low Engine oil and low coolant level when I start up. But I checked engine oil it seems fine..:
    Apr 2004
    aul, may be getting at shutoff. My son has the car 150 mi away. Will request update.
    What is significane of msg at shutoff?
    Long Beach, CA
    Quote Originally Posted by Eric Clark
    That's a lot of labor - Heater Core. How long did it take you guys?
  1. "Coolant Level" Warning
    By Calico_NC in forum 5 Series BMW
    Last Post: 03-16-2006, 04:49 PM
  2. low oil level warning
    Last Post: 02-15-2006, 04:51 AM
  3. coolant level warning
    By Karl in forum 5 Series BMW
    Last Post: 01-11-2005, 11:50 PM
  4. Coolant level warning
    By e34 in forum 5 Series BMW
    Last Post: 09-21-2004, 10:16 PM
  5. Coolant level warning but no overheating?
    By BAYEMVAY in forum 5 Series BMW
    Last Post: 09-20-2004, 02:32 PM
