Results 1 to 5 of 5
Thread: check engine
    Australia
    Default check engine
    Hey guys
    I've read about the early 535's not being able to take the check engine light very well, as a result coming on when nothing's wrong.
    A while back i put a bulb in there so i could do a stop test. Has come on during driving a while ago, lasted about 30sec and never came on again. However in the last 24 hours i've had it come on quite often, lasting 30-60secs at a time and going off again. Stomp test produces no fault code.
    Is this the "false alarm" i read about or am i to expect something??
    Thanks everyone
    Honolulu
    Default I get this once in a while
    I put a bulb in, and after a good up hill run the light comes on for just a few seconds.
    I think it is just a temporary fault or something.
    Australia
    I thought about it but if there is/was a temporary fault, shouldnt the lamp stay on until you did the stomp test and cleared the fault(s)?
    Thanks for reply mate
    Honolulu
    Default Not sure
    I have seen check engine lights go on / off on other cars too, without a reset and no fault codes.
    But the eariler E34s that didn't come with a bulb installed are said to have the light go on and off. thats why some people only put the light in to do the stomp test, then take it back out.
    Australia
    ah! That's it then. See i read about that (mine's 1989 - an early one ) and bulb was never in the cluster, i can tell. So after i put it in it didn't give out "false alarms" so i assumed mine's the one that proves the rule wrong Looks like it's not.
    Guess i was just uneasy coz it intensified drastically in the last 24 hrs. Probably just a coincidence.
  1. check engine light flickers with engine miss
    By cobb535 in forum 5 Series BMW
    Last Post: 05-25-2007, 11:21 AM
  2. "Check Engine" rough idle after engine Shampoo??
    By Guelphguy in forum 5 Series BMW
    Last Post: 04-27-2006, 01:06 PM
  3. Check Engine!!!!
    By saj3n in forum 5 Series BMW
    Last Post: 02-27-2006, 01:47 PM
  4. Engine check on a 520
    By tibbe in forum 5 Series BMW
    Last Post: 09-18-2005, 02:16 PM
  5. Replies: 6
    Last Post: 10-10-2004, 03:49 PM
