Results 1 to 3 of 3
Thread: PowerFlex Bushings
    Mar 2004
    Gainesville, FL
    Default PowerFlex Bushings
    Interesting that I can't find a direct thread on these powerflex bushings.
    Does anyone out there use them?
    Does anyone have an opinion here or there?
    Just wondering cause I am close to having this car running right, and I would hate to miss out on these exciting looking parts.
    "eliminate shaking", "install yourself with no machine press", "better than urethane", "last forever"
    hmmmmmmmmmmmmmmmmmmmmmmmmm
    A Young Man with a Plan
    ericbendler@yahoo.com
    Your talking about something like this. Your better off doing this. If your hungry for more, consider these.
    Cheers and good luck, tell us how you go.
    Quote Originally Posted by ericbendler
    Default Sorry Kriss,
    It turns out that the flexane released a bit from the rubber bushings. There isn't really a problem as the m5 thrust bushings are still ok. That captured flexane ended up much softer than needed. I'd suggest using the e34 m5 thrust bushings.
    Quote Originally Posted by BigKriss
    erased due to slander
  1. Spare E31/32/34 Powerflex bushes
    Last Post: 10-06-2009, 01:46 PM
  2. Powerflex bushings - fitting
    Last Post: 07-02-2009, 12:31 AM
  3. POWERFLEX: Initial verdict
    Last Post: 05-09-2008, 08:59 PM
  4. PowerFlex kit subframe bushings finally arrived
    Last Post: 04-22-2008, 07:10 PM
  5. Powerflex thrust arm bushings??
    By Guelphguy in forum 5 Series BMW
    Last Post: 04-03-2007, 11:06 PM
