Results 1 to 8 of 8
Thread: Foglight Problem
    Apr 2005
    Philadelphia
    Default Foglight Problem
    Front passenger's fog light error appears, light does not come on, bulb and fuse are fine... any suggestions?
    PA
    Quote Originally Posted by saj3n
    Check Control Module failed.
    Hockinson, Washington
    The wire going into my foglight is frayed and does the same thing. Try wiggling the wire going into the foglight with it turned on and see if it does anything, if it does, repair the wire.
    Default Jon K
    Why should the check control have failed?
    So if the fuse seems to be o.k., I would despite of this check it and change it. If that is o.k., follow the lines to the fog light and check with the multimeter where the power is stopped.
    Alexlind123 gave you a hint what could be the cause.
    PA
    Oops shogun, didn't see that he said the fogs are inoperable. Stupid medecine makes me zoney.
    Ohh, if it is just medicine, that's fine.
    In my case and my age it is probably Alzheimer ;-)
    Kentucky
    Dirty/corroded contacts on the wiring going into the fogs perhaps?
    Apr 2004
    Remove and open up the LKM. One of the mini relays will likely have a fractured solder joint to the PCB. Reflow the solder to repair.
  1. anyone have a pic of the foglight cover?
    By 525i winter driver in forum 5 Series BMW
    Last Post: 06-05-2008, 12:34 PM
  2. My old FOGLIGHT problem...
    Last Post: 04-19-2007, 07:36 PM
  3. Stubborn Foglight
    Last Post: 01-07-2007, 05:51 PM
  4. My loose foglight fix...
    By Dan in NZ in forum 5 Series BMW
    Last Post: 09-04-2004, 05:55 PM
