The dash automatically warns you when the temperature is near freezing, so you know to drive more carefully. That is a 'feature'.Originally Posted by Shanghyd
Can't help you otherwise. Sorry.
89 BMW 535i, European version.
When I push in on the turn indicator it should cycle through the info from/on the OBC right?
When I first start the car it shows -37C in the dash. (That's a seperate issue).
When I press in on the turn indicator, either pressing and releasing quickly or holding it in, I get the same results. Nothing.
Any ideas?
Have you programmed the display for the info you want? I forgot how but let's see...
http://www.bimmer.info/forum/showthr...ht=program+obc
I didn't get the P1 or anything. I tried the key in both positions. Is there a seperate fuse for this?
