Thread: Can I put an overdrive 5th gear in my '93 525i?
    Nov 2005
    Los Angeles, near Torrance
    Default Can I put an overdrive 5th gear in my '93 525i?
    My '93 525i has a 1:1 ratio 5th gear, but I would prefer a more relaxed journey with possibly an 0.92 or 0.85 gear. Can such a modification be made to an otherwise-stock manual transmission?
    the fun-est but most expensive would be score a 6 speed from a euro e36 m3 and get a drive shaft built to fit it, otherwise a taller diff ratio would make highway driving better, lower #s = taller
    i am eventially going to get one of these for my diesel http://www.gearvendors.com/ so i can have a double overdrive .73 allready but it redlines at 3k so double od would be nice 4-500 foot pounds of torque gives you some options , too bad they don't make them for bimmers
    Nov 2005
    But lower numbers also mean slower acceleration, so to counter-act this I would need to get a lighter flywheel. Is that correct?
    yep slower off the line, flywheel wouldn't help much but 30-40 more hp would help counter it nicely if you didn't go too low with the ratio
    Quote Originally Posted by theirongiant
    As I think Winfred is saying, there's not a lot that can be done without spending a bit of cash.
    The economical "upgrade" is a tradeoff -- slower acceleration/higher theoretical top speed.
    It's probably not worth monkeying around with a high mileage 220 to begin with. I don't know what Bill or Winfred have to say about it, but it has always been my understanding that they're not noted for their durability.
    best, whit
  1. Fifth gear no go?
    By Jehu in forum 5 Series BMW
    Last Post: 09-11-2008, 04:00 PM
  2. overdrive gearset "squeaky" when turned by hand
    Last Post: 03-25-2008, 07:08 PM
  3. has anyone here ever done the 4l30e/a4s310r overdrive gasket?
    Last Post: 02-28-2008, 02:33 PM
  4. 1984 528e transmission overdrive probs.
    By wayne stevens in forum 5 Series BMW
    Last Post: 07-10-2005, 12:14 AM
  5. gear box oil
    By Arxon in forum 5 Series BMW
    Last Post: 12-28-2004, 08:40 PM
