Results 1 to 10 of 15
Thread: Brake Light OBC message
    Aug 2005
    Toronto
    Default Brake Light OBC message
    Driving home yesterday I got the "1 Brake Light" warning on my dashboard. My brake lights are fine. I only noticed that one of the little bumper-mounted red sidemarkers is out. Is that what the message is referring to? It's not really a brake light...
    Jay Lebo - Toronto, Canada
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    Sachs Suspension Kit
    E.A.T. Chip
    Houston, TX
    Check everything, change anything that doesn't check out - the check system is pretty sensitive. You could have an intermittent open circuit from a bulb that's about to go toes up, or you could be suffering corrosion in a plug or socket. I am a believer in using contact cleaner to make sure all those electrons don't struggle too hard to get where they're going. Good luck.
    Aug 2005
    Toronto
    Thanks.
    Funny thing just happened.
    I went down to my car and started her up. The bulb I mentioned above is still out, but I drove the car for 10 minutes without getting a warning message.
    The car was off for a while, then I started her up again, and got "Brake LT Circuit -- Check Owner's Manual" on the dashboard. That's a different message from before.
    Turned the car off again for a while, then started her again and drove home -- no error message this time.
    Strange, huh?
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    E.A.T. Chip
    I received both of those messages before one of my brake bulbs kicked the bucket. The messages were intermittent until the bulb went out. I suppose you could wait until one fails since that appears to be the direction its heading. Also, make sure there isn't any moisture in the tail lights since that can cause problems very easily.
    Wellington,New Zealand
    brk light circuit is ussually caused by the brake light switch...much easier to change on a rhd car..........
    Aug 2005
    Toronto
    Okay, all the lights are now working.
    I am no longer getting the "1 Brake Light" message, but I am still getting the "Brake LT Circuit -- Owner's Manual" message.
    What's up with that? Everything seems fine.
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    E.A.T. Chip
    see above message
    Aug 2005
    Toronto
    I worked it out: loose connector on the rear light cluster.
    Thanks for the help.
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    E.A.T. Chip
    Aug 2005
    Toronto
    False alarm. Things were okay for about 30 minutes, then the "Brake LT Circuit -- Owner's Manual" message returned. And now I have NO BRAKE LIGHTS!
    Neither left nor right cluster brake light works, not the center-mounted light in the rear window, and not the brake light mounted on my spoiler. Taillights, reverse lights and turn signals are okay. Fuse #1 in the engine compartment is okay.
    What's going on? Help! My car is now dangerous and illegal
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    E.A.T. Chip
    You Need A New Brake Light Switch!
  1. no more 1 brake light message
    Last Post: 10-28-2008, 09:55 PM
  2. Brake Light, Tail Light, Licence Plate warnings
    Last Post: 09-24-2007, 05:01 PM
  3. Brake lining message
    By ScottyWM in forum 5 Series BMW
    Last Post: 10-06-2006, 11:25 AM
  4. Trailer light message
    By Espen in forum 5 Series BMW
    Last Post: 03-23-2006, 06:15 AM
  5. Brake Light Circuit Error Message
    By BlackOnBlack in forum 5 Series BMW
    Last Post: 04-06-2005, 08:58 AM
