Results 1 to 4 of 4
Thread: Trans pan magnet
    Jun 2005
    Nashville, TN
    Default Trans pan magnet
    I am in the process of changing my trans fluid and filter and had a question. When I cleaned my pan out the magnet was covered in metal shavings. My filter also looked to be pretty well clogged. Is this normal for a high mileage trans? As long as it doesn't go fubar on me I should get much better performance just because of the increased flow.
    Hockinson, Washington
    My magnets were covered in metal shavings as well, thats what theyre there for As long as there are no chunks of metal in the pan you should be fine.
    the buildup is fairly normal if never changed, it comes from the clutch friction disks and the steel disks between. Nevt filter replacement should be much cleaner at appx 30k.
    Long Beach, CA
    Quote Originally Posted by mbogosia
    Just did mine and had the same experience. It didn't look like mine had been serviced in a long time, if ever.
  1. Magnet Marelli bendix
    By baksa in forum 5 Series BMW
    Last Post: 06-09-2006, 12:41 AM
  2. Switching Auto trans to Manual trans
    By oleh in forum 5 Series BMW
    Last Post: 03-21-2006, 04:39 PM
  3. Need help with Trans Mod indicator but trans runs fine.
    By bimerguycw in forum 3 Series BMW
    Last Post: 02-05-2006, 09:34 PM
  4. need help trans
    By HAWK42 in forum 7 Series BMW
    Last Post: 07-28-2005, 10:31 AM
  5. Theoretical Trans fluid question 5hp-18 530 trans
    Last Post: 09-22-2004, 01:01 PM
