Results 1 to 10 of 17
Thread: fresh meat for the killing
    baton rouge, loserana
    Default fresh meat for the killing
    you think the frame is dammaged!
    Unregistered Guest
    Default You can buff that out..
    ..some of the stuff I saw in an informercial could take that out in no time. It would also restore your health and make chicks dig you.
    Yes exactly, it's called Pops A Dent and its available at most reputible body shops.
    Cincinnati Ohio
    I wouldn't touch that one with YOUR 10 ft. pole. YIKES !!
    Miami Lakes, FL USA
    Default Is that the back of your yard?
    Looks like a lot of orphans lookin' for homes. What's the engine in that coupe?
    Brian C.
    There is nothing worse than a brilliant image of a fuzzy concept. -
    .............Ansel Adams
    s52 3.2 m motor
    Miami Lakes, FL USA
    Default Mmmmm....wouldn't THAT make the Pig squeal! ; )
    s52 3.2 m motor
    actiually i am in the process of building a m20 that will be close to the same power as a s52, ill be a little down on power by time the smoke has cleared ill be around 220, s52 is 240. i think the e30 is lighter but the more modern car has a close ratio tranny
    Miami Lakes, FL USA
    Default Cool....it must be fun....
    .....to be able to have the time, place, access to "projects", and the knowledge to play with things like that. My '95 525ia has the M50tu. When was the last year that BMW used that engine....or is it still used in new 525's?
    Brian C.
    this is us cars in general too many euro versions to go through
    91 was the 1st year of the m50, non vanos, big lumpy cams, no knock sensors, double valve springs, a fun motor nice power surge when on the cam
    93 was the technical upgrade "tu" m50, single stage intake cam timing advance, smaller cams, less compression, knock sensors, air mass sensor
    96 m52 (328/528) same motor from the outside but with a 1/2" longer stroke same bore, not sure about the specs on the cams but the heads the same
    i don't know much about the m54 besides double vanos and aluiminum block
  1. BMW Meat! Who's in, Chicagoland, Sept 20th
    By Bimmer Nut Ed in forum 5 Series BMW
    Last Post: 09-26-2009, 12:58 AM
  2. My Pics from the Chicago Meat.
    By bimmerd00d in forum 5 Series BMW
    Last Post: 06-13-2006, 06:15 AM
  3. Please help guys, this is killing me.
    By Rob in forum 5 Series BMW
    Last Post: 04-03-2006, 12:42 AM
  4. Replies: 1
    Last Post: 01-10-2006, 09:45 AM
  5. E34 Killing Batteries
    By dsio in forum 5 Series BMW
    Last Post: 05-02-2005, 09:25 AM
