Results 1 to 10 of 13
Thread: E34 won't start :(
    South North CA, Bay Area
    Default E34 won't start :(
    Howdy,
    My E34 (M20B25) just died on me. The car won't start, engine does not rotate. I'm looking into it right now but I'm pretty busy. Is there a common ignition type of failure among E34s? I'm looking for a quick check guide where too look first for an E34 that won't start. The battery is fine.
    Aug 2004
    Netherlands
    Does the starter actually react at all when turning the key? If it does, but the engine seems jammed, try turning it by hand at the crank with a 22mm spanner. If it doesen't turn, check if the cam beld isn't broken.
    There's no reaction whatsoever when trying to start up. "try turning it by hand at the crank with a 22mm spanner" Could you elaborate on that? Much appreciated.
    Some more info. When I attempt to start I hear two quick "clicks", plus the idle control valve is buzzing.
    the battery real low?
    Aug 2005
    east anglia uk
    sounds like a dead battery to me!
    Battery is fairly new, lights etc light up bright as they should. It's not showing dying battery symptoms.
    Jumped the starter relay, no results.
    Btw, what's making the "tick tick" noise at start up? I'm trying to determine up until where the ignition system is working.
    Default Identify pin 11 of diagnostic connector, and check ...
    you have 12 Vdc there when key starting. If not, jump 12 Vdc there and see if it cranks.
    If 12 Vdc there and no starting, you have starter issues, as long as all connections to the starter are solid.
    http://www.unofficialbmw.com/e36/ele...ce_lights.html
    Javier
    Quote Originally Posted by Javier
    Javier
    I checked, there's 12vdc at port 11 when attempting to start. I've got a strong feeling it's the starter. How can I tell if it's the ignition switch and not the starter? Also, in case the ignition switch is bad, can still bump start the car?
  1. e34 won't start
    By Tiger in forum 5 Series BMW
    Last Post: 03-19-2008, 07:12 PM
  2. She won't start
    By Pete D in forum 5 Series BMW
    Last Post: 10-08-2006, 03:01 PM
  3. start, sputter, stop, no start.. huh?
    By olsan100 in forum 5 Series BMW
    Last Post: 10-04-2005, 10:16 AM
  4. Replies: 3
    Last Post: 09-26-2005, 01:50 AM
  5. car won't start
    By pyro in forum 5 Series BMW
    Last Post: 03-11-2005, 02:26 PM
