Results 1 to 7 of 7
Thread: Door Seals
    Mar 2004
    Brisbane, Australia
    Default Door Seals
    Is there any way of taking the seals off the door without destroying them? I'm talking about the ones that are inconveniently stuck to the door! I was thinking maybe heating them up with a hot air gun to soften the glue? Any tips?
    Rory:
    Both the door and chassis side seals will pull right off, sometimes with a bit of gentle manipulation -- there should be no glue; if there is, somebody screwed it up.
    best, whit
    them wheels look hot!!!
    Mar 2004
    Brisbane, Australia
    Quote Originally Posted by lowell
    Rory:
    best, whit
    thanks Whit, i tried pulling it off gently and it started to tear the seal. it's the one that runs the whole way round the door itself past the lock etc. underneath it i can see a white coloured adhesion strip. is this normal?
    Mar 2004
    Brisbane, Australia
    Rory,
    "Whit, i tried pulling it off gently and it started to tear the seal."
    They are dead. I know it from my parts cars. Just try to replace them. If you always treat the rubber with the BMW Gummipflege and the previous owner has done it carefully, then o.k.
    my own 750 main driver is almost 18 years old now, no problem except in one small corner with the door rubbers. But that also depends on where you live (climate/temperature change/in sunlight parking always or sometimes etc),
    but the above statement tells me:
    Buy new ones. Sorry
    Malaysia
    Rory:
    best, whit
    the chasis side is straight fwd.it can be pulled right off.the door side has two rubber seals.the inner one uses very strong white colored double sided tape,which when removed,will not re-stick.however,i have seen cars,especially after going thru a paintjob,with these seals re-glued.
  1. use of E39 door seals in E34 - DIY
    Last Post: 06-25-2010, 06:23 PM
  2. Source for Door Seals
    By av8r in forum 5 Series BMW
    Last Post: 03-26-2007, 03:05 PM
  3. New Door Seals Come Preshrunk!!
    By John B. in forum 5 Series BMW
    Last Post: 02-04-2007, 08:30 AM
  4. door seals
    By jjdickm in forum 5 Series BMW
    Last Post: 05-11-2006, 02:29 PM
  5. Source for Door Seals
    Last Post: 10-17-2005, 06:09 PM
