what is the part number for the cluster bulbs?I noticed to day that although my SI is lit the little compartment next to it is not so i cant see the inspection or oil dervice indication.....i can see something but its very dim.....or is this a caps issue(the odometer lamp also is intermittent)
Take out your instrument cluster, open it (by untwisting black thumbscrews - you'll figure it out once you have it outside), inspect all the bulbs and their contacts - clean all the contacts and replace the bulbs (they're cheap). You can also check for bad capacitors while you're at it.
