Results 1 to 10 of 15
Thread: 635Csi intake manifold
    Aug 2004
    Dubai
    Default 635Csi intake manifold
    I saw a full manifold unit of the old 635Csi car, I have heared before that they allow more air in as they are wider than the new M30 engine.
    any more information from you mates ?!
    Default You heard wrong, the passages in the newer m30 manifold
    are bigger to allow more flow since it has bigger intake valves as well in the newer motor.
    Quote Originally Posted by grave77
    Aug 2004
    Dubai
    so 635i intake monifold and valve is smaller?! ..does that apply the old 745i manifold too?
    Boston & Attleboro MA
    For the most part, the 3.5L M30 was the same for all 635s. From 1978-81 did have a slightly larger bore 93.4 vs 92 for all other years and from 82-86 it had a 10-1 compression w/ DME II. The only real difference was the DME, L-Jet 1978-79, DME I 1980-81. From 1987 on it was DME III with a 9.2-1 compression, which is the same for the E34 89-91 right?
    Current
    2008 M5 6 Spd
    2000 Z3 2.8 5 Spd MSport
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    Aug 2004
    Dubai
    well I think the 9.2:1 is the old M30 compression. E34 M30 has something like 12:1 I think .... maybe some guys will correct me.
    bigger intake passages result in lower torque at lower rpms and for the most part will posibly de-tune the whole intake system and make your car slower.
    Aug 2004
    Dubai
    I never knew that Jeff, but why then many people try to enhance the flow from the passages ( Intakes, air filters, bigger throttle butterfly ..etc ) and after all it gets slower takeoff?! I thought this would make the engine gain better compression
    Nov 2004
    Split, Croatia
    You cannot change the compression ratio by simply replacing your intake manifold. Unless you turbo/supercharge your car, you won't gain much by tampering with the intake manifold - and as Jeff said, you'll end up with a detuned car that will be slower.
    Aug 2004
    Dubai
    so that ends up the intakes issue.
    Does a camshaft change the compression ratio? for example stage II camshaft. also do I need new rockers and springs or will the OEM work with it?
    k....what a cam does is change the dynamic compression at a different time compared to the stock cam...not static compression. You could in theory change to a larger lift cam with the same timing and get higher static compression at a slightly higher RPM range. If you went with a larger lift cam with more duration it would make more power at a higher RPM but you will sacrifice lower RPM power. This kind of discussion could go on forever. What you want to do is the most important aspect than just sticking in a bigger bumpstick. Usually if you go with a higher lift and duration cam it will tend to run better at higher ropms, so if thats whats going to happen the rest of the package will have to be tuned for that modification such as higher compression, larger valves, free flowing exhaust, stronger valve springs that wont bottom out from higher lift etc etc etc.... At that point you can concider the larger intake manifold.
  1. m50 intake manifold
    By shadowpuck in forum 5 Series BMW
    Last Post: 03-09-2008, 12:39 PM
  2. intake manifold
    Last Post: 03-06-2006, 11:40 AM
  3. anyone want a v8 intake manifold - used???
    Last Post: 01-08-2005, 08:49 PM
  4. Intake Manifold
    By jj7 in forum 5 Series BMW
    Last Post: 11-28-2004, 12:18 PM
  5. Why would there be oil in the intake manifold?
    By Anton CH. in forum Engine & Drivetrain
    Last Post: 02-14-2004, 09:12 PM
