Results 1 to 10 of 30
Thread: New steering wheel installed (pic)
    Philly, PA
    Very good choice, I have the same wheel and absolutely love it. You got a great price. I got mine when they were on ebay trading for about US$250+ shipping. So I went the slightly more expensive route and bought one new at the dealer from my friend who works there. Was about US$350 but i got a brand new one.
    BTW, if you experience the horn going off randomly its because there is excess metal from the casting process that needs to be ground off that is contacting the column and setting it off. I think you can figure out how I know.
    And its time to get a nice leather shift knob to match!!!
    Nov 2004
    Split, Croatia
    Quote Originally Posted by Alan_525i
    I would like a new one too, but it's around 500 EUR here, so I figured that used one will do the job for 1/5 of the price
    I didn't experience that till now - maybe it affects only new ones? This one is MY 90 - I think the excess material got ground off during 15 years of use
    You are reading my mind! I was planning on getting a nice leather illuminated shifting knob, but I'll probably have to get a new one, and it's not very cheap :/ It will cost me more than the steering wheel, probably
    Apr 2004
    I recently bought an identical wheel in Germany - not yet arrived. Did you place spacers on both sides of the hub? I know that one is recommended/required on top to cover the exposed splines and to allow the nut to torque against the hub .... but am unsure if one is required on the back side.
    Nov 2004
    Split, Croatia
    Quote Originally Posted by GS535i
    There was only the one on top, in my car, so I left it that way. If my previous steering wheel didn't require a spacer on the back, I'm sure this one doesn't either.
    Apr 2004
    Reston Va
    Did you use your original Slip ring when you changed out the wheel?
    Also - do you have the part # for the wheel?
    Looks like a sweet mod. - JT
    Johntee540
    1994 540/6 Black - Tan - 199k
    Nov 2004
    Split, Croatia
    Quote Originally Posted by Johntee540
    What is a Slip ring?
    The P/N is: 32332226085
    Indeed it is
    chicago (NOT chicagoland)
    John,
    Ignore the part number given here; that only applies 89-92/93. Look at the links for the whole story.
    http://www.bimmernut.com/wwwboard/e3...ges/82506.html
    http://www.bimmernut.com/wwwboard/e3...ges/39869.html
    But yes it is a sweet mod. Any e36 wheel will fit, even the airbag ///M will have the smaller diameter and the thumb bumps. They can be rare though and i do like the simple look of the 3 spoke better anyway.
    Here's one on fleaBay
    http://cgi.ebay.com/ebaymotors/BMW-M...QQcmdZViewItem
    This one pops right on. Even though the ad does not mention e34 fitment. No other parts needed.
    If that black plastic tab on the back side breaks in shipment, all you'll lose is the turn signal return. It's a $15 part (maybe $30 i forgot).
    Jon K's is from an e46 and i'm not sure if all the buttons the airbag or even the horn werk (horn probably). The airbag from an e36 ///M3 should be totally compatible........again, good luck finding one used.
    ”Hang up & Drive!”
    94 530iT&A 125K, ‘Helga’ (for sale *sniff*...almost )
    92 325i 120K, ‘Rolf’ (blown clutch *rolleyes* )
    91 Volvo 745T 191K, ‘Thor’ (13 psi beater *biggrin*)
    93 NX2000 151K ‘Carla’ (she’s alive...WOOT )
    "Those who would give up essential liberty to purchase a little temporary safety deserve neither liberty nor safety." -- Benjamin Franklin. Kinda makes the ‘Patriot Act’ an oxymoron, eh.......
  1. Replies: 5
    Last Post: 12-18-2006, 10:18 PM
  2. Replies: 13
    Last Post: 08-10-2006, 08:19 AM
  3. Clickin noise from wheel/lumping in steering wheel
    By m5james in forum 7 Series BMW
    Last Post: 11-19-2005, 11:26 PM
  4. Can a 1995 540i steering wheel be installed on a 1992 535i?
    By pmlmotorsports in forum 5 Series BMW
    Last Post: 05-08-2005, 09:00 PM
  5. E36 M3/M-Sport Wheel Installed
    By Shaun in forum 5 Series BMW
    Last Post: 03-30-2005, 07:50 PM
