Results 1 to 10 of 20
Thread: Double Locking
    Default Just follow Uscharalph advaice and check the harness...
    by the driver's side hinge in the trunk lid. It will do no harm to check this frequent source of lock system issues.
    Javier
    Sep 2005
    Invercargill, New Zealand
    Quote Originally Posted by Javier
    Javier
    Just checked the trunk wiring... found 6 wires all with the casings broken, though wires still connected. Taped them up, but the doors still not locking normally. Any suggestions?
    ANswer is back in the thread. Shogun: microswitch- Sean and Johan's pages..
    Default OK, now unlock the system using the 3 ....
    available key holes. I mean, both front doors and trunk. Remember you should not double lock the doors for the trunk key hole to be able to unlock the system.
    I'm interested to see if there is one lock that works fine, as it would be the culprit. My car is doing the same thing "Unlock / lock / unlock again", only noticed it when engine is running (typically when I'm leaving a passenger, may be also in "D", and have not been able to debug it, though I have not put enough effort).
    I fear the culprit is the trunk lock, may be it is acting lazy, and it is issuing a lock command early after unlocking the system. If so, may be some lube in the linkage will help, as long as the micro switch inside the actuator is working fine (It is if lock works fine with the key).
    Javier
    Sep 2005
    Javier
    The trunk unlocks and locks the car normally, but both driver's and passengers door both double lock. So that makes it the boot lock then?
    Default Have you tried the unlock operation with trunk lock ...
    in both locked positions, I mean, horizontally, and locked vertical? is there any difference?
    Javier
    Sep 2005
    Javier
    Sorry, I'm not sure i understand what you're saying. I'm such a noob.
  1. '92 double panel sunroof
    By scott in forum 5 Series BMW
    Last Post: 11-14-2018, 03:42 AM
  2. ::.. Double-clutching to pass...
    By Qube in forum 5 Series BMW
    Last Post: 08-31-2006, 09:14 AM
  3. sorry double post...
    By kick7ca in forum 5 Series BMW
    Last Post: 03-10-2005, 07:30 PM
  4. Double Checking Torque
    By Kane in forum 5 Series BMW
    Last Post: 10-28-2004, 09:16 PM
  5. Will valet key double lock??
    By PhilipJCaputo in forum 5 Series BMW
    Last Post: 06-18-2004, 11:45 PM
