all the same checks as you describe,with no luck.I ended up taking the car in to an independant only to find the abs computer to be at fault.Replaced unit with second hand one and the light went out.$350 nz.good luck.
My 95 525i ABS light came on. (I checked it is not working). I checked all the sensors and connectors. Any idea what else I can check?
Where is the ABS relay located?
take the black cover off the abs pump, theres two relays under there. if the light comes on after the car starts moving it's a sensor
