Results 1 to 3 of 3
Thread: Instrument light randomly on/off
    Jul 2005
    Default Instrument light randomly on/off
    Hi.
    The instrument light turns off sometimes when I put the turning signal on, and after a short time it comes on again. Can be turned off w/o touching any switch too and randomly turn on again. Helpes sometimes to turn light off/on/off/on/off..
    Have put in a new instument light dimmer 60W, and removed and refitted the connectior on tha back of the light switch. Will install a new light switch tomorrow but have a feeling it's doesnt make any improvement.
    Also the trip ( km meter that can be resetted ) will sponataniousy reset it selves at some engine startup.
    Can it be a supply voltage drop somewhere?
    Or any hint / tips?
    Sven-Erik Tiberg
    Lulea / Sweden
    -93 520iAT ( 90kmls ), -76 R100RS/4V, -94K1100LTSE
    Jul 2005
    Still have this "challange"
    Got the bently manual yesterday and found a great site at http://www.e38.org/e34/ with a lot of wiring and electric troubleshooting.
    /Tibbe
    Default If sunroof switch light is also involved ...
    and the park lights are not, the problem is in the light switch or its surroundings (before dimmer whell). If Park lights (right side) are also involved, the problem is in fuse F5 and its surroundings. Do not trust fuses just by looking at them, specially when you have intermitent issues. If sunroof switch/park lights are not involved, then the issue is at dimmer switch and its surroundings.
    If the light of the dimmer switch itself is not involved, then the issue is located in the wire comming out of the dimmer switch towards the lamps being the problem. (Gray/Red wire).
    Javier
  1. instrument cluster light question
    By Travis_WA in forum 5 Series BMW
    Last Post: 04-24-2008, 09:53 PM
  2. Hazards come on randomly
    By bulldog_shotgun in forum 5 Series BMW
    Last Post: 03-29-2006, 05:36 PM
  3. Why is lic.plate light showing in my instrument cluster?
    By Bimminator in forum 5 Series BMW
    Last Post: 01-28-2006, 09:45 PM
  4. Instrument light replacement help needed.
    By Showngo in forum 5 Series BMW
    Last Post: 09-18-2005, 06:46 AM
  5. sunroof randomly opening?
    By rickm in forum 5 Series BMW
    Last Post: 12-15-2004, 06:16 PM
