Hi.
Had a litle rattle sound under the front of the valve cover of my -93 520IA so I lifted the cover and all seems OK, just moved the DOHC chain tensioner a bit up and down. And the sound seems to be gone. Knock knock.
Saw a unit I never seen in a car before the "AT adjustment unit" in front of the intake side camshaft. Whats that? "Adjustabe Timing"? of intake valves.
/Tibbe
Found on the internet: http://www.bmwworld.com/technology/vanos.htm
It's the VANOS unit variable input camshaft timing on the M50 engines.
-------------- Qoute from web page ------------:
VANOS operates on the intake camshaft in accordance with engine speed and accelerator pedal position. At the lower end of the engine-speed scale, the intake valves are opened later ( 12.5 degrees ) , which improves idling quality and smoothness. At moderate engine speeds, the intake valves open much earlier, which boosts torque and permits exhaust gas re-circulation inside the combustion chambers, reducing fuel consumption and exhaust emissions. Finally, at high engine speeds, intake valve opening is once again delayed, so that full power can be developed.
More info: http://www.ukcar.com/features/tech/Engine/vv/vvt_3.htm
It has variable timing, does it have a PWM or on/off control valve?.
