Results 1 to 3 of 3
Thread: Tyre wear question
    Mar 2004
    Cambridgeshire, UK
    Default Tyre wear question
    I've got a bad tyre wear issue with my 540i - the outside edges of the front tyres have worn most of the way through the tread. The rest of each tyre still has about 4mm left. This is over the course of about 10000 miles of mostly motorway driving.
    So, it's clear that there must be some alignment issue here, and I'd like to know what the concensus is so that I don't get the wool pulled over my eyes when I take it to a dealer or mechanic to get it sorted.
    Thanks in advance...
    --Chris
    these cars do tend to wear the outer front tires and the inner rear tires. At only 10,000 miles I would say you have alignment issues and should get them taken care of and then maybe rotate the front to rear and make sure the wear is better before purchasing new shoes.
    Mar 2004
    Cambridgeshire, UK
    Thanks for that. Rotation isn't an answer, unfortunately, as the front tyres are approaching the legal limit on how much wear can exist across the width of the tyre.
    I get the impression this sort of thing can be caused by tightening up the thrust arms without the suspension loaded correcly first. Is my supposition correct?
    I'm in for a wallet-bashing next weekend, I fear, whatever happens...
  1. E34 tyre wear pattern
    By ktteoh in forum 5 Series BMW
    Last Post: 01-17-2011, 05:46 PM
  2. Front tyre inside wear
    By E34-520iSE in forum 5 Series BMW
    Last Post: 10-19-2006, 05:14 PM
  3. Do speed sensors wear out and wiring question
    Last Post: 09-11-2006, 12:00 PM
  4. Tyre wear and bad judder from steering wheel
    By shuriken in forum 5 Series BMW
    Last Post: 06-10-2006, 09:21 AM
  5. urgent tyre size question.
    By E34 Touring in forum 5 Series BMW
    Last Post: 04-06-2006, 05:11 PM
