Thread: Door Open!
    Mar 2004
    New York
    Default Door Open!
    for some reason today the door open message keeps coming up while im driving... i know all the doors are closed cuz i pulled over and opened and shut each door any help on this matter is highly appreciated TIA
    Default What about interior lights, did they turn on?
    Javier
    Check the contacts in the doors. Maybe one of them is jammed or needs cleaning.
    Mar 2004
    New York
    yea the lights come on and everything! at times the gong would go off repeatedly 5 or 6 times
    Jun 2005
    Cheshire, UK
    Do a search of this forum, this issue comes up time and time again.
    Basically it's usually due to wear in the pin on the b-pillar that the lock wraps around - usually the drivers door. The proper way to fix it is to remove the door panel and adjust the switch in the door lock. My way was to wrap electrical tape around the b-pillar pin to thicken it and remove the slack.
    Hope this helps.
    Mar 2004
    New York
    sounds great guys ill look into it as soon as i can... thanks!
  1. Door does NOT open up most of the times
    By elbasha in forum 5 Series BMW
    Last Post: 07-07-2008, 03:01 PM
  2. Door won't open?
    By Ross in forum 5 Series BMW
    Last Post: 05-02-2008, 02:10 PM
  3. Door Open
    By vegasjoe in forum 5 Series BMW
    Last Post: 03-05-2007, 07:33 AM
  4. Hood Open, Door Open, Trunklid Open
    By MDT in forum 5 Series BMW
    Last Post: 07-20-2005, 02:25 PM
  5. Door Won't open! HELP!!
    Last Post: 04-20-2004, 12:16 AM
