Results 1 to 9 of 9
Thread: OBC and digital Dash question...
    Sep 2005
    Swansea South Wales
    Default OBC and digital Dash question...
    Ive got hold of an OBC from an earlier 89 car, a 530/535 series. The info on the net suggests it needs a coding plug, when used with the 'low' dash inst panel.... What is the difference apart from the coding held in the different inst panel, between the 'low' and 'high' inst panels....?
    My car has the same (looks like anyway...) inst panel as the car the OBC came from, Would I still need the coding eeprom to fit inside the OBC?....
    Nov 2004
    Split, Croatia
    Quote Originally Posted by High Compression II
    Low = No Check Control and no coding plug
    High = With Check Control and coding plug built-in
    Sep 2005
    Swansea South Wales
    Guess mine's the 'low' then.........
    What does the 'check control' look like, and what does it do??
    Only had a brief look at the 530 inst panel.......
    Aug 2005
    Toronto
    The check control looks something like this, I think:
    Nov 2004
    Split, Croatia
    Quote Originally Posted by jaylebo
    Yes, but that's the E28/E30 check control panel
    The high version of the cluster looks like this:
    Sep 2005
    Swansea South Wales
    Do you know, if its possible to fit this type inst panel in place of the low type, or is this just a huge bag of trouble?--I would need to change the rev counter and probably other things too.....
    The reason I ask, is its probably cheaper from my breakers to get the whole inst panel, than it would be for the coding plug for the OBC from the stealer!
    Nov 2004
    Split, Croatia
    You'll have to check if you have the complete harness + you'll have to buy a check control module.
    Sep 2005
    Swansea South Wales
    In the vehicle, where does the check control module live?--The donor vehicle is still more or less complete apart from some engine parts.....
    I could get the matching unit from that......
    Nov 2004
    Split, Croatia
    In the fuse/relay box under the bonnet on the driver's side, where LKM is.
  1. Digital Temperature gauge
    Last Post: 09-29-2009, 06:41 PM
  2. Digital Display
    By deadpheasant in forum 5 Series BMW
    Last Post: 09-06-2006, 08:57 AM
  3. Dash Display question
    By mbogosia in forum 5 Series BMW
    Last Post: 07-05-2005, 10:46 AM
  4. 89 520i analogue dash to digital
    By adystorr in forum 5 Series BMW
    Last Post: 04-13-2005, 03:40 AM
  5. OT: In the market for a digital camera
    By warton in forum 5 Series BMW
    Last Post: 04-29-2004, 03:36 PM
