Results 1 to 2 of 2
Thread: Anyone hunting air-leaks causing idle problems
    Default Anyone hunting air-leaks causing idle problems
    Make sure your sump bolts are all tight. I've been chasing for leaks for a while now, replacing many things, rebuilding the head and so on- just noticed quite a few of my sump bolts were a bit loose... not sure if this was me being sloppy at some point earlier or if it might be common thing, just wondered how they might be on other member's cars. I seldom get the car above me so they managed to live for some time both 'out of sight and out of mind'...
    Any air leak into the engine will roughen the idle and make it hard to tune the idle air bleed screw. If your engine will still idle with this tightened up, you have a leak somewhere that is giving it the air it needs to operate... and unmetered air it doesn't need when you are accelerating (causing a lean condition).
    Nick
    baton rouge, loserana
    id tighten them up pretty much every oil change on the 535, ****ing cork gasket, if id known id lock tighted the bolts when i changed the gasket with the engine on the stand
  1. Idle FAQ a fix for hunting idle on '89 525m?
    Last Post: 08-19-2009, 01:56 PM
  2. surging/hunting idle when cold..help!
    By romeox929 in forum 5 Series BMW
    Last Post: 03-03-2007, 07:19 PM
  3. Hunting down the M50 idle issue.
    By SnakeyesTx in forum 5 Series BMW
    Last Post: 11-12-2006, 08:54 PM
  4. hunting idle and 1222 stomp code
    By carolina525 in forum 5 Series BMW
    Last Post: 10-30-2004, 02:33 PM
  5. Hunting idle, ICV,TPS, etc.
    By BAYEMVAY in forum 5 Series BMW
    Last Post: 08-19-2004, 11:23 AM
