Results 1 to 10 of 12
Thread: White smoke from exhaust
    Aug 2005
    Grand Forks, ND
    Default White smoke from exhaust
    I notice that when the weather is cold (below 40 degrees), my 535iM emits white smoke from the exhaust. Now, I've searched this topic and found that it could just be condensation because of the exhaust system being so complex. However, it seems like my car smokes the most of all cars on the road when I drive. There is sometimes tons of smoke and it drifts and surrounds the car at stoplights. The smoke doesn't smell, and it's very light. Also, I'm not loosing coolant, and the engine seems to be running smoothly. Is this just condensation, or something more sinister?
    -Martin
    Boston & Attleboro MA
    Mines been doing that since I got it and its nothing serious. Unless you are loosing coolant, smellin gas/coolant, have milky substance in your oil, overheating, a hole in a cat, failing emisssions or have CEL.... then its normal
    It goes away after like 20 mins right?
    Current
    2008 M5 6 Spd
    2000 Z3 2.8 5 Spd MSport
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    Hockinson, Washington
    My car also does that when i drive it when it is cold. Once the exhaust system is heated up it goes away. I can observe other cars on the road which have varying degrees of steam exiting the exhaust pipe, probably dued to their different starting times and exhaust configuration.
    Jan 2005
    Chicopee, MA
    I would not worry about it. Smae thing here cold car + cold weather = smoke
    BMWoooom
    thud thud thud
    Calgary, AB
    Yah mien seems to have the most smoke out of all of them too, I htink its a normal thing
    better than whack whack whack
    thud thud thud
    Jan 2005
    How long does this go on for? When its' cold yeah you'll get some condensation but after a while it should stop. ONce the engine/exhasust system is totally hot, say 10-15 minutes the amount should decrease and eventually cease altogether.
    Calgary, AB
    It won't cease if the air is cold outside but yes it does die down sometimes.
    when its real cold and I hammer it the cars behind me cant see and have to slow down...thats cool stuff man!
  1. White Smoke!
    By Roderick in forum 5 Series BMW
    Last Post: 12-17-2006, 12:02 AM
  2. M20 White smoke help
    By 520Ichester in forum 5 Series BMW
    Last Post: 02-16-2006, 04:36 PM
  3. White Smoke
    Last Post: 12-01-2005, 03:15 PM
  4. Replies: 14
    Last Post: 08-10-2005, 01:17 PM
  5. White smoke from exhaust at idle
    Last Post: 09-30-2004, 09:48 PM
