Originally Posted by
mikell
Maybe the switch is intermittent, after all. If you have volts and the lamp is not burned out, that should pass current, which heats the filament and makes light. I know of nothing in the circuit that would limit current if you have 12vdc present. Does it make a diff if the trunk is open or closed? Could it be that bad old trunk wire wear thing?
I assume that both lamps behave the same.
How about testing the switch with a continuity checker or ohm meter? Or, bypass the switch with a jumper and see if that gives good current to the lamps.
Good luck.
