Originally Posted by
Mike L.
Anybody every have their rear windows lower on their own? Halloween just passed, maybe it's possessed??? Wife was driving on the highway and they both lower half way.
It happened 2 more times today. One window all the way down, the other half way??
Any ideas would be greatly appeciated. I noticed the controls will stick and slamming the rear door will "unstick" it. But this is weird...
Disconnect the both rear door window switches and the 4-way window switch block in the center console, disassemble them (it requires only a small flat screwdriver) by prying off the top and clean the contacts inside - you can also inspect if the lightbulbs are OK and you may also lube it up with WD-40 or something similar. Also clean the connectors before reattaching the switches back.
