Results 1 to 9 of 9
Thread: how to tell rear shocks are bad?
    Lexington, Kentucky
    Default how to tell rear shocks are bad?
    I replaced my front struts a few months ago with stock Boge struts at about 110,000. No other changes. Made a big difference in lean and control. Now have almost 117,000.
    The rear shocks/struts are original. How can I tell if they need replacing? If so, what components besides the struts should be replaced.
    TIA
    Russell, they'll leak -- can't miss it. The other diagnostic is to determine how well they dampen bumps.
    Replace rear shock mounts. Check the bump stops and dust shields (EDIT: actually, dust boots -- not sure why I called them shields), replace if necessary. Springs may merit replacement, as well -- measure the ride height to get an idea of how they're holding up.
    best, whit
    Lexington, Kentucky
    Default ride height seems ok
    Does not look like any droop in teh rear. However, I think rear damping is going. I feel as if there is a lot more wheel movement in the rear than the front.
    Hobart, Tasmania, Australia
    Allow this V70R Volvo to demonstrate...
    Gone but NEVER forgotten. :'(
    And then...
    Damn! That's more than a little squat on acceleration...
    My sig pic shows some good rear end squat on acceleration. A few suspension shops do free shock tests, I took mine in and they attached an electronic device and bounced the car, measuring rebound or something. Mine were at 80% or so.
    Mar 2004
    MASS
    Default Replace them.
    If your shocks aren't leaking its hard to tell until you replace them. I did the opposite from you and replaced the rears first with Boge at 120,000 miles. Had no leaking. Big improvement in roll. And I can feel the difference from front to rear stability.
    The rears are also easy to replace. If you decide to do so make sure you get new bump stops, spring retainers, and shock mounts. Also, you'll need to remove the bolts on one side of the dog bones.
    Gooch
    '94 5 speed
    Lexington, Kentucky
    Quote Originally Posted by Gooch
    Some say they are hard to replace
    Way easier than front to replace. Sign of bad shock in rear is poor control when hitting bump while turning because the wheel will continue to bounce... losing traction. 120K on Boge is unheard of. They do not last that long.
    Lexington, Kentucky
    Default Then mine are worn out
    They are the orginal shocks-thanks.
  1. Rear E31 shocks
    By grave77 in forum 8 Series BMW
    Last Post: 03-31-2007, 05:05 PM
  2. E32 750il Rear Shocks
    By jackjakosalem in forum 7 Series BMW
    Last Post: 06-29-2006, 06:52 AM
  3. Rear shocks 525i
    By yaofeng in forum 5 Series BMW
    Last Post: 04-20-2006, 05:08 AM
  4. Anyones got some old 530/535/540 rear shocks?
    By genphreak in forum 5 Series BMW
    Last Post: 04-30-2005, 12:09 AM
