Results 1 to 10 of 11
Thread: i started my heater core project, i have some pics!!!
    SCHUYLKILL COUNTY, PA.
    Default i started my heater core project, i have some pics!!!
    i have 2 1/2 hours into the project & tomorrow i will have help to finish.
    it only took me a year & a half to get the bravory to do it. i would rather change my valve cover or intake gaskets.
    http://www.tntcomp.com/tim%20s/heatercore.htm
    tim s.
    Aug 2005
    Newton, MA
    Quote Originally Posted by tim s
    tim s.
    THANK YOU
    I need to do the same thing on my car i fear. Do I need to tear apart the steering wheel and the entire dash board completely?
    -Artem
    Long Beach, CA
    tim s.
    Damn! That's a a lot of work.
    Default what you see should be it i am told by alldata software.............
    i did need to remove the steering wheel but not the cluster.
    i am now going to hopfully finish it.
    thanks
    tim s.
    Good Luck, tim. Good that you make pics. Also take notes where which part or screw was located. I did some bigger projects before and I know that it is sometimes difficult to remember.
    Jan 2005
    Reno, NV
    Wow, from the pictures, it looks like you did more work then you needed to..... I did my heater core right when I purchased the car, so I knew nothing about anything on the car. Took 6 or 8 hours, I can't remember. Do mark all of yor screws on a paper towel or something. I ended up with two screws and I have no idea where they went, because I put a screw in every hole???!!!!.......
    535 Rear Wheel Enjoyment
    Default i just finished it!!!!!!!..............
    i spent a total of 6 hours on the heater core & 3 hours on the expansion valve & an a/c leak. the only thing i dis-assembled that i did not need to was the cluster. everything else needed to come out. as i removed panels i laid the screw on the panels in the trunk so i would know what was what. when i re-installed everything i ended up installing screws that where missing & did not have anything left over. if i needed to do it again i am sure it would take less time.
    do not let the expansion valve fool you, it is one of those things that even though you see the entire thing does not make it easy to change.
    Thanks to everyone on this board, i don't think i would have tried to do these things without the help & support!
    happy camper, tim s.
    Long Beach, CA
    Congrats. Everything works OK?
    Default yes, i tested all my switches & so far so good!!!
    Quote Originally Posted by uscharalph
    thanks for asking.
    tim s.
    Long Beach, CA
    thanks for asking.
    tim s.
    Cool!
  1. Heater core removal with pics
    Last Post: 10-02-2013, 04:05 AM
  2. E32 heater core replacement - pics
    Last Post: 04-11-2012, 07:50 PM
  3. heater core replacement - pics
    Last Post: 12-18-2007, 01:30 PM
  4. some pics of our heater core change
    Last Post: 10-20-2007, 10:51 PM
  5. e34 project getting started
    By ska-texas in forum 5 Series BMW
    Last Post: 06-19-2006, 09:45 PM
