Results 1 to 10 of 12
Thread: Machining rotors
    Jan 2005
    Chicopee, MA
    Default Machining rotors
    Can you machine slotted and drilled rotors? I got brembos both sides, they seem to be wrapped. Not even after a year of driving. It looks like I only have to do the front.
    BMWoooom
    Aug 2005
    Toronto
    You can, but everyone here will tell you that if you machine a rotor that's noticeably warped you'll seriously reduce your brakes' resistance to fade and the rotors' ability to withstand the stresses of normal use. In other words, you'll be shopping for new rotors soon anyway.
    I would think that Brembos ought to last more than a year. Maybe someone can shed light on why you've gone through them so fast.
    Jan 2005
    Chicopee, MA
    I am using Rybestoes QS for pads, the problem started about two months ago. Right now it's shaking really bad. I still should have warranty on them somewhere. Exactly thinking Brembo should do quality parts, they make brakes for Ferrari don't they. Maybe I was pushing them too hard.
    BMWoooom
    It's stupid to machine any BMW rotor. The company explicitly condemns it for M car hardware, and I've replaced enough machined rotors on stingy peoples' cars to know that it's not a fluke or a freak accident.
    Get new rotors, they're cheap.
    best, whit
    Long Beach, CA
    best, whit
    I agree with Whit.
    Boston & Attleboro MA
    If by "not even after a year" you mean the rotors were brand new and after less than a year this issue arised, check with where you bought them about warranty/defective. There have been cases of bad lots of rotors from different manufacturers.
    Other than that, never turn rotors, thats the consensus opinion.
    Also check mis installation that could of caused the warping.
    Current
    2008 M5 6 Spd
    2000 Z3 2.8 5 Spd MSport
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    another back to basics scenerio im tring to work on.
    pull all the roters, sand, wire brush clean till theres nothing there, I mean a clean surface. then clean the back of the rotor mating surface before you go and cut a decent rotor.
    then reassemble and try to break in propely...blue balls is normal.
    edit: i mean blue rotors after break in is normal and a good sign.
    Jan 2005
    Chicopee, MA
    I tkink I will go with zimmerman and try to return the old brembos.
    BMWoooom
    Hmmh,
    if you ask such a question and tell us that they are in not even a year:
    "a year" does not mean anything.
    How many miles or km did you do in that time, that is the point.
    Some people drive 50 K miles a year, other less than 5.
    Apr 2004
    I'm having the same problem with my frt brakes.Replaced them 3400 miles ago with QS pads and Raybestos rotors.So far it only is noticable above 60 and when hot.I'l have them checked and maybe turned otherwise I will get Ate again.
  1. machining 750 bushes for e28
    Last Post: 04-15-2006, 04:55 PM
  2. Replies: 8
    Last Post: 09-03-2005, 02:46 PM
  3. Turning/machining the brake rotors
    By xtmsports in forum 5 Series BMW
    Last Post: 04-16-2005, 06:28 AM
  4. Rotors
    By scottiej04 in forum 5 Series BMW
    Last Post: 10-20-2004, 06:54 PM
  5. Machining Flywheels
    By Bob Gardner in forum 5 Series BMW
    Last Post: 06-18-2004, 11:03 PM
