Sure it's not belt squeal? Entirely probable given the M30 and Vbelts.
A quick way to check the vacuum on the M30 is to pull the dipstick or oil fill cap. Idle should get very rough as the engine runs at atmospheric, then return to normal when closed. Not entirely failsafe, doesn't beat a vacuum gauge, but it'll tell you if there's a major air leak.
best, whit
