Results 1 to 7 of 7
Thread: M5 Gauges
    Hobart, Tasmania, Australia
    Default M5 Gauges
    Hey all...
    I heard somewhere that you can 'tune' the speedo if it reads slower/faster than actual road speed... True??
    If so, could it be 'tuned' enough to read correctly if I were to put the facia of an M5 300km/h speedo in the dash?? Not replacing the whole cluster, just removing the black plastic speedo dial, and replacing it with the M5 unit??
    Alot of folks here judge a car by the top speed on the dash, so if I can fit a 300km/h unit in there, will certainly raise a few eyebrows... And most of them are silly enough to believe it!!
    Gone but NEVER forgotten. :'(
    And then...
    Nov 2004
    Split, Croatia
    Quote Originally Posted by Nick.Hay
    It's cheaper to make them believe your dick is huge.
    Long Beach, CA
    Quote Originally Posted by Interceptor
    Low blow.
    Nov 2004
    Split, Croatia
    Quote Originally Posted by uscharalph
    Low blow.
    I hope he won't hold a grudge After all, we all have white E34s, that counts for something, right?
    Uh... It is.
    And then...
    Yeah that could be possible with the speedo. You could always just get an M5 cluster and put it in... Not sure if it's compatible, but it's probably been done. Adding an oil temp sensor would be the big issue.
    There are instructions on the web for re-calibrating the speedo.
    Wellington,New Zealand
    is this the obc correction???does that recal the speedo too
  1. Just won some new gauges off ebay
    By Felixdacat in forum 5 Series BMW
    Last Post: 11-18-2006, 09:59 PM
  2. Accuracy of Gauges?
    By 92E34 in forum 5 Series BMW
    Last Post: 11-03-2006, 06:43 PM
  3. Gauges not working
    By houndjjj in forum 5 Series BMW
    Last Post: 07-17-2006, 06:11 PM
  4. Retrofitting M5 gauges into 525?
    By granit_silber in forum 5 Series BMW
    Last Post: 12-17-2005, 04:46 PM
  5. gauges again!
    By ukm5 in forum 5 Series BMW
    Last Post: 05-11-2005, 08:57 AM
