Results 1 to 10 of 16
Thread: Viscous Fan Coupling
    Aug 2005
    Default Viscous Fan Coupling
    Hi!
    This viscous fan coupling, what is it for? I was told it adjusts the rotational speed of the fan based on temperature, right? The mechanic even stopped the fan with his finger and said mine is useless.
    Long Beach, CA
    Oh yes, then it is totally useless
    http://www.mwrench.com/Whitepapers/FanClutchtest.pdf
    That's a great document, Shogun.
    Aug 2005
    Thanks Shogun
    With the mentality of sticking fingers in the vacinity of a spinning fan, a new mechanic is in order.
    Quote Originally Posted by t_marat
    Australia
    haha i dare him to stick a finger in my fan!
    Hi!
    Actually, I regularly stop the VC fan when it's not "running" with my hand. Not on M70s, but...
    If your mechanic intimated that the fact that he could stop it with his hand indicated that it was bad, you probably want to find a new shop for the car.
    The oil in the coupling activates only after it has reached a certain temperature. They're supposed to run for a few seconds after the engine is started, then rotate freely until the engine bay gets hot enough to activate the clutch again.
    best, whit
    Long Beach, CA
    Quote Originally Posted by romus
    I'm going to check to see how many fingers my mechanic has. LOL!!
    Australia
    not many if he's as gifted as the one up there.
    Aug 2005
    Quote Originally Posted by lowell
    best, whit
    It was summer, and we had to drive to that shop, so the engine was rather hot.
  1. Viscous Fan Clutch Failure
    By JMI in forum 5 Series BMW
    Last Post: 07-27-2010, 03:56 AM
  2. e34 viscous fan tapping
    By dwaynos in forum 5 Series BMW
    Last Post: 06-06-2008, 08:08 AM
  3. lower steering coupling joint
    By iainand in forum 5 Series BMW
    Last Post: 08-07-2005, 05:35 AM
  4. Does the 4 bolt steering coupling loosen?
    Last Post: 06-27-2004, 04:10 PM
