Results 1 to 7 of 7
Thread: 15mm offset on E34 Wheels.....
    Default 15mm offset on E34 Wheels.....
    Hey guys, first post so hopefully you can help me out. I have scrolled for this specific question to no avail, so sorry if Germans:
    I am considering a set of ADR Designs M Classic BBS wheels for an E34. The specs are as follows:
    Bolt Pattern: 5X120 - I know this is correct
    Hub Bore: 74.06
    Offset: 15mm
    I know the factory specs call for a 20mm offset and am not certain regarding the hub bore or whether the 5mm offset differential will cause significant problems.
    Can anyone enlighten me as to whether this particular set of wheels will actually fit my 95 525i?
    Many thanks in advance.
    Renton,WA
    NJ
    Default They'll be fine
    I'm running BBS RCs with the exact same dimensions and 245/45/17 tires all around. They fill out the wheels wells very nicely.
    Quote Originally Posted by robertsonarch
    Hub Bore: 74.06
    Offset: 15mm
    Drew Z
    Formerly 540iT/6, now . . . 3, 5, 7
    NJ
    Default with one caveat
    You will need hubcentric rings (parts# A670 from tirerack @$4.00 ea).
    Hubcentric rings
    Quote Originally Posted by DrewZ
    Drew Z
    Kentucky
    She is a sexy bitch; I think she should lose the bra though.
    Default e31 wheels have a 15mm offset and work well.
    Bellevue WA
    86 Porsche 951 - Track Toy
    Jul 2005
    NOR CAL
    I run bbs rx's and they all have a 10mm offset and they work fine on my ride. just make sure that you get an allignment after you install them.
  1. Offset of stock wheels
    By JMI in forum 5 Series BMW
    Last Post: 03-29-2007, 12:07 AM
  2. 18" BBS wheels offset question?
    By lamb chops in forum 5 Series BMW
    Last Post: 06-15-2006, 08:52 AM
  3. FS: 18x8 M5 Wheels et:15mm with tires only $475+ Shipping
    By ericcamaro in forum 5 Series BMW
    Last Post: 05-30-2006, 02:22 PM
  4. Are offset of the 17" BMW X5 wheels 20 or 40?
    Last Post: 03-03-2005, 10:12 PM
