Year... Model.. Tran of the car?
We need some more info...
-Charles
Hello,
I have problem with vibration on the front at speeds 50-60 mph and oil despairing every 700-750 miles about 1q
Did anybody have same problems? Please help.
cca
-Charles
I miss my e34
it is 535 manuel , 200000 miels 1989.
cca
thrust arm bushings are probably toast, have the whole front end inspected for play and replace everything in question, also inspect and tighten the nut behind the wheel.
1. Please fill in all the info in your profileOriginally Posted by E.serg 535
2. What grade of oil are you using? Oil consumption of about 1 liter on 1000 km is normal for that kind of mileage if you're using 0/5/10w40 oil. Also, check for gasket leaks, especially the oil pan, oil filter housing, valve cover, etc.
3. Vibration is probably caused by worn bushings in the upper/lower control arms. Also check the subframe bushings and the steering box (adjust the nut behind the wheel if necessary, as Jeff suggested)
4. Did I mention that you should fill out all of the info in your profile?
Thanks for the response gays.
I use 5w30 synthetic Mobil 1 oil.
I get low oil message when I drive 700-750 miles strait or during the mount and I don’t see any oil leak marks on the ground and engine looks ok too.
cca
Erm... don't mention it... I guess...Originally Posted by E.serg 535
Try switching to 10w40 Mobil 1 and see if it lowers your oil consumption.Originally Posted by E.serg 535
Then it probably burns some oil, which is normal for your mileage. As I said before, try using thicker oil, for example 10w40 or even 15w50.Originally Posted by E.serg 535
Don't forget - BMW recommends 10w40 for a brand new engine! Maybe it's wise to switch to 15w50 after 200k miles.
Typos can be pretty funny sometimes.![]()
Cheers
All the best
Bob
[QUOTE=E.serg 535]Thanks for the response gays.QUOTE]
err ummm no thanks...
Did anyone mention that you should fill out your profile?
Are you ****ing with us or bad at english...or both?
the a & u are on opposite sides of the world so I can only assume your ****ing with us.
Got your panties in a bunch or something Jeff......
I miss my e34
